D:GravityRose Online 3DDATATERRAINO_Range.TBL file open error
I am the administrator of my computer. Nevertheless I am getting the following message saying:
GravityRose Online 3DDATATERRAINO_Range TBL file open error
I have made several attempts like to restart to get rid of this. But nothing worked. What should be done now?
Any suggestion?
Please.
Best Answer by Edmund Joseph
Answered By 0 points N/A #145293
The file named O_range.tbl is corrupted .This could have probably occurred because of some error while updating. You will have to open the Patcher. If you don't know how to then follow these steps:
1. Go to settings ( Right hand side on the top).
2. Click on Advanced.
3. Check all and Defrag.
Answered By 5 points N/A #145295
Hi there user:
Checking and defragging should be the first option to fix this issue.
But upon my own checking, and a few research on-line, most user/gamers didn’t have their ‘sigh of relief’ after doing this option. The annoying error is still there. And so the last option will be to uninstall the game/application and install it again. Or you may want to get another game/application to escape the annoying error totally.
Thanks for asking here at techyv.com
Best regards,
