Diagnosing Whirlpool Duet Dryer Error Code At Home.
What are whirlpool duet dryer error code? How do we solve those error codes? If it is possible to solve them at home without any help from professional technician?
There can be many error codes for this. There are many reasons for the appearance of these error codes. Some of them could be due power failure, primary control failure of the machine, keypad/user interface failure, Exhaust thermistor open, inlet-temperature sensor failure, motor drive system failure, moisture sensor open, moisture sensor shorted, restricted outlet airflow, no communication between ECB and the user interface.
Do not panic when these error codes appear. Just disconnect the power supply. Wait for some time and then plug in the power. Resetting the unit will solve some of the issues. Some of the elements may be in a need of replacement. So call for the professional executive to send some technician to solve this issue.
