Diagnosing Whirlpool Duet HT Error Codes-F/Hindividually.
I am getting some whirlpool duet HT error code on my unit. How do we solve those error codes? Is it something very serious?
Getting error codes on the duet HT machine is quiet normal. There are numerous reason for this flashing of error codes. They may be user-interface assembly failure, no entry of water into the machine, drain time is more than 8 minutes, any problem in the water temperature sensor, failure in the drive motor tachometer, failure in the motor control unit, and serial communication fails, failure in the dispenser circuit and failure in the EEPROM.
Check for any blockage in the drainpipe and inlet water pipe too. Some elements may need replacement and some of them could just need maintenance and care. Try not to keep any heat-generating device nearer to the unit.
