Diagnosing Whirlpool Oven Error Codes In Minutes.
What are whirlpool oven error codes? How do we solve those error codes? If it is possible to solve them at home without any help from professional technician?
The reason for this appearance of error codes are numerous. If there is any problem in the child lock then an error rec\code LOC will appear. If the error code F1 appears then there is some defect in the electronic oven control. If the error code F2 appears then it indicates the oven temperature is quite high. You need to check the control circuitry and the relays to get out of these errors.
If the error code F3 or F4 appears then you need to replace the temperature sensor. If error code F5 or F7 appears then you need to replace the control board.
