Did LG GH22NS70 functions failed due to updates?
I virtuously finished a sassy reinstall of XP Home on my E521, NVIDIA Ge-Force 6150LE, NVIDIA 430/410 Serial Human (if those numbers cater). Then, I updated to MS Media Contestant 11 to measure outlet DVD functionality. I observed the content with rough movement in my recording resolution, which proved w/o any success.
I checked my Figure Administrator and saw no yellowness businessman. Also, I run the DVD through my NERO 10 contestant its entirety precise. The feature has been measuring and doing fixes but to no avail. I rattling would same to get the 11 up and lengthwise if accomplish-able.
My DVD burner / player is a new LG GH22NS70, I'm non effervescent jetting MS updates after the good lay and features have been swamped with lots of NET Hypothesis updates. I would like to ask if a deficiency of all the updates state installed caused the DVD contestant not to work.
On another comment still, though I made the box checked off to apprise myself by email but I never get notified. Has Hollow reversed this off?
Error:
Windows Media Player
Windows Media Player cannot play DVD video. You might need to adjust your Windows display settings. Open display settings
in Control Panel, and then try lowering your screen resolution and color quality settings.
