Difference between OLED and LED screen
Organic Light Emitting Diode (OLED) is an exceptional type of LED. It uses natural compounds for emissive electroluminescent layer. OLED is smaller than the LED and it is attained through distinct manufacturing procedures. That is why the LED could not attain high-quality resolutions on tablets, smartphones and laptops.
The key difference is that OLED screens doesn't need a backlight. They can make their own light using an electric current that flips through diodes organic. The LED on TV and LED lamps are created within the liquid crystal display. Therefore, while removing the established light sources, there are various layers of rising thickness.
Because OLED produced its own light, it can create almost any color of the scale. LED screens is suited on passing light within a color LCD condition to create color.
Hi Lutfurrahman,
The difference between LED and OLED
LED: is the same as LCD screen only that LED use side light as opposed to the LCD which uses fluorescent tube.
The back light do appear at the back which turn out to be grey .
It has no life time indicated.
It is a semiconductor light source.
It emit low intensity red light
This is heavy in weight
OLED: (Organic Light Emitting Diode).
It is light emitting diode. The electroluminescent is film of organic compound.
It emit light in response to electric current.
It has a life span of 15000 hours
It is lighter in weight
NOTE:
The LED screen is heavy than OLED screen
Light Emitting Diode which is commonly referred as LED. The full abbreviation of the LED explains it's meaning also that it emits light when the current passes within the device.
Whereas OLED is flexible one which full abbreviation is Organic Light Emitting Diode that is smoother thus making pictures/images & videos running with more quality.
