Difference Between Angular And React
Angular is a JavaScript framework written in TypeScript, developed and maintained by Google. React is a JavaScript library which is developed and maintained by Facebook. Angular is considered to be a full-fledged framework it provides, with routing libraries so that you can start coding.
However, the drawback is that you have less flexibility. React is JavaScript Library (just the view), gives you much more freedom. You can choose your libraries. Angular uses a regular DOM while React uses a virtual DOM. React require knowledge of JavaScript, but with Angular, you must know the specific syntax.
Fiber is another feature of React, which enhances its speed. Angular uses two-way data binding while React uses one-way binding. You can conclude that these are some of the best technologies in the market. You can choose any one of them.
Notifications
