Difference between datagrid and gridview
There are a number of differences between GridView and DataGrid. First of all the GridView has various new features and merits over the DataGrid control. Features like; -Richer design time capabilities, -data source capabilities which are a bit improved, -It also has a customized pager user interface with a pager template property, not forgetting the additional column types and design-time column operations. The GridView and the DataGrid also differ in such a way that they have different custom paging support and also different event models.
Nice reading
The DataGrid Web server control is a powerful tool for displaying information from a data source. It is easy to use. You can display editable data in a professional-looking grid by setting only a few properties. At the same time, the grid has a sophisticated object model that provides you with great flexibility in how you display the data.
The GridView control enables you to select, sort, and edit the values of a data source displayed in a table where each column represents a field and each row represents a record. The GridView control supports these features:
