Difference between freeware, shareware and software
The title speaks for itself:
What’s the difference between freeware, shareware and software?
Thank you for answering!
Good question, hope my answer will resolve your query. I will try to explain the difference by giving you example.
Firstly software, which is basically a computer program or set of computer program, that’s instruct computer what to do and what to do.
Freeware is now a type of software, that is available for free and anyone can use that, you can say it as free software.
Shareware is also type of software, which is initially free or trial version is free, but afterward they ask for some money.
Thus you can also say shareware as a trial ware.
Hope you now the difference between these three.
Shareware also indicates trialware or demoware which means the software that you’ll be acquiring is in a trial version or demo version. With this program’s status, you only have a certain amount of time or a specific period to use the software after it was first installed. After the time has elapsed, you will no longer be able to use it and will now ask you for its CD key or activation code. During this period the software will usually disables itself to force you to either buy it or remove it from your computer. Shareware is usually offered with limited features. All its features and functions will only be unlocked and made available after purchasing a license key.
Generally, software can be referred to the application or program that you run or use on your personal computer. It means computer instructions or data. It is anything that can be stored electronically. Software is often divided into two categories. Systems software includes the operating system and all the utilities that enable the computer to function. Applications software includes programs that do real work for users.
Freeware also means “free software”. It is software that you can use on your computer for free. Meaning, you don’t have to pay for it to use it. But freeware usually has restrictions or limitations on the product’s usage. This is typically the opposite of commercial software which is clearly sold for profit.
