Difference between Internal and External IP Address
I’m really confused about the difference between internal and external IP address. How do they differ from each other?
The difference between the internal IP and External IP Address are
Internal IP address this is commonly we called Local IP Address these are usually what we configure in the router. External Ip Address these are the addresses that the ISP (Internet Provider) will provide to you and these will be broadcast to the internet.
So, If you have this Internal Ip add
192.168.1.12 (this your IP address that the router assigned to you.) ( Internal IP Add)
When you surf the internet. Let say you open www.yahoo.com
The router recognise your Computers IP ADD(192.168.1.12)
The router will send request to the modem that you want to open www.yahoo.com
The modem recognise your request and will process your request.
When you open the site www.yahoo.com, In Yahoo webserver they will log your External IP address, in which the ISP provides it to you.
Every ISP have different External Ip Add will assign to you. that is what we called Dynamic IP Address
When you say Dynamic and Static
Dynamic – Flexible,random (IT terms)
Static – Fix, Permanent (IT terms)
I hope this will help you understand.
