Difference between iPhone 4 and iPhone 4s
Hi Jazzreyes,
Oh, iPhone 4 and iPhone 4S, two of the most popular smart phones ever created. Although they are quite similar in a lot of aspects, their differences are quite significant. Indeed, they come from the same iPhone 4 series, but their differences are truly worth considering.
Let’s begin with their price. For an iPhone 4 at 8GB, it has a price tag of $99. For the iPhone 4S, its price varies with its drive size; a 16GB, a 32GB, and a 64GB is priced at $199, $299, and $399 respectively. Moving on, let’s take a look at its hardware. iPhone 4S utilizes a dual core A5 chip while iPhone 4 utilizes single core A4 chip. Surely, iPhone 4S performs faster than iPhone 4. Well, there is a quite difference in their camera’s capability. iPhone 4 captures up to 5 megapixels, and records up to 1080p of quality at a 30 fps while 4S captures up to 8 megapixels, and records up to 720p of quality at the same fps.
Lastly, their battery life is what we should consider too. iPhone 4S’ battery life stays much more longer than iPhone 4’s battery life when used in certain operation, but when in stand by iPhone 4 stays longer. Well, there are really a number of aspects you should consider when we compare these Apple Smartphones; however, it all depends on you.
>>Mathew Joni<<
The difference between iPhone 4 and iPhone 4S is you have SIRI on iPhone 4S, basically you can’t tell the difference between iPhone 4 and iPhone 4S until you use the phone.
Because they have the same color black and white, and almost identical shape, lets see the difference. In terms of processor, iPhone 4S use Apple 4A processor while iPhone 4S use dual core Apple 5. On primary camera, iPhone 4 uses 5 megapixel, while iPhone 4S uses 8 megapixel a/f with flash and face detection. About video recording, iPhone 4 uses 720p at 30 fps while iPhone 4S 1080 at 30 fps, they both have Bluetooth, and almost the same weight, while there is a big difference on price. iPhone 4 sells at $99 (8gb) while iPhone 4S retails around $199-$399 depends on the memory capacity, the larger the memory the higher the price.
Hi Jazzreyes,
There are several differences between iPhone 4 and iPhone 4S. Kindly see the information below:
iPhone 4S has a intelligent personal assistant called Siri, although doesn't have it. iPhone 4S has A5 dual core chip that is 7x much faster than A4 chip that iPhone 4 has. iPhone 4S has a line at the left side top while iPhone 4 doesn't have. The weight of iPhone 4S is little bit heavier than iPhone 4. It increases its weight up to 3 grams.
In terms of Camera, iPhone 4S has 8 megapixel iSight Camera while iPhone 4 only have 5 megapixels iSight Camera. And also, iPhone 4S has five element lens. In terms of Video recording, iPhone 4S has 1080p for video playback while iPhone 4 only got 720p. Also, iPhone 4S has a video stabilization while iPhone 4 doesn't have. Lastly, iPhone 4S talk time will take up to 8 hours on 3G connection while iPhone 4 will take up to 7 hours.
Have a great day ahead.
Notifications
