Difference between local user account and a domain user account
Domain (Authority) account is when it initiates meeting (session) by means of a domain (authority) account in a network. A domain (authority) controller is necessary to be able to form the accounts of beginning of the meeting (session). Then it would be to join the team (equipment) to the domain (authority) and to use a beginning of the meeting (session) of the central database. It is a question of having a domain (authority) account to control what can be done in the team (equipment) and if it is possible to initiate a meeting (session).
Account of local user is a configuration of the account in the machine. For defect, there are some accounts. It can have both. It can have a domain (authority) user and has then that the user as a local manager so that they can realize admin things in the proper team (equipment).
Domain (Authority) account = administered in a centralized way.
Local account = administered locally in the proper team (equipment).
Thanks a lot.
User accounts determine the actions that a user can carry out on a computer. The type of user account determines the privileges given to a user. There are two types of user accounts, one is the local user account, which is an account created on a computer. They don't usually have all the access or the authority to change certain services, while the domain user account has complete authority on Windows security features. They can also be the network administrator.
A local user, in Windows, is one whose username and encrypted password are stored or saved on the computer itself. When a user logs in as a local user, the computer or Windows checks its own list of users and its own password file to verify if you are allowed to login to the computer.
The computer or system will then apply all the permissions and restrictions assigned to your user account for that computer like if you can use the CD-ROM or install applications. A domain user, on the other hand, is one whose username and password are stored or saved on a domain controller rather than the computer where the user is logging into.
When a user logs in as a domain user, the computer requests the domain controller for the privileges assigned to you. When the computer receives the correct response from the domain controller, it logs you in with the right permissions and restrictions. According to Indiana University Knowledge Base:
“Domain users evolved in response to the challenges administrators face when managing large numbers of computers, peripherals (for example, printers, network storage), services, and users. When a network has a large population of users on various computers, it is difficult to maintain information for every user on each individual computer.
The task of managing so many users is simplified by allowing each computer to validate access through a central source to see if each user can log in and use computing resources. With one centralized source of user info, network administrators have only a small set of computers on which to maintain user information.”
