I wonder what is the difference between Apple MacBook Pro with Retina Display and without it?
Difference between Macbook Pro with Retina Display and without it
I will tell you the advantages of the Retina Display. Then you can understand the difference between normal screen and Retina screen. The MacBook Pro with Retina Display starts $2,199. But it isn’t a bad price for the Video editors, photographers and Graphic Designers.
The resolution of 2,880 by 1,800Â pixel.
It shows every pixel in a five- mega pixel shot.
It is thinner, lighter and lacks a DVD drive.
It even lacks and Ethernet port for Internet connection.
View the following picture. Then you can recognize the resolution.
Icons are displayed on the screen of a new 15-inch MacBook Pro with Retina display. The screen features four times as many pixels as a standard display.
