Difference between Samsung Galaxy Note 10.1 and iPad 3
Anyone knows the difference between the Samsung Galaxy Note 10.1 and iPad 3?
Which one has higher specs?
Personally it all boils down to your preference but, I will lay down their specifications for you.
Let’s start with the iPad. The iPad that I’m going to be talking about will be the iPad 3 WiFi which is the latest iPad available and released March 2012. This iPad has a larger screen resolution (1536 x 2048 pixels) that will let you enjoy movies better. It boasts scratch screen, available at 16/32/64 GB capacities. It has WiFi and Bluetooth 4.0 connectivity. It has a 5mp camera at the back and a 2mp camera at front that will let you capture pictures and videos.
This newest iPad is running Apples latest operating system for their mobile platform, iOS 5.1 and has a dual-core Cortex-A9 processor. This newest iPad is available in two color variants, white and black which both look stunningly beautiful.
Next up will be the Samsung Galaxy Note 10.1N8000. This tablet will be released approximately by the end of July this year. According to the specifications stated on the Samsung Website, this tablet will sport an 800 x 1280 pixels screen resolution. This tablet is also available at 16/32/64 GB capacities and the same WiFi and Bluetooth 4.0 connectivity. This tablet comes with a memory card slot that will let you expand the internal memory capacity up to 32 GB.
This tablet comes with a 3.15mp camera with LED flash and a front facing camera as well. The Galaxy Note tablet will run the latest Android Operating System 4.0.3 – Ice Cream Sandwich that will be running on a Dual-core 1.4 GHz ARM Cortex-A9 Processor. The Galaxy Note 10.1N8000 is available in black and will come with an “S-Pen” which looks and acts like a pen that greatly improves user experience.
Hope this helps a lot in making your decision on your next would be tablet.
Samsung Galaxy 10.1 and Apple iPad 3 are equipped with
Feature |
Samsung Galaxy 10.1 |
Apple iPad 3 |
face |
screen |
10.1 inch resolution of 1280×800 PLS TFT Display |
9.7 inch resolution to 2048 x 1536 (doubling it in both directions)
pixel density |
149 ppi(Low pixel density) |
264 ppi(High pixel density) |
Camera resolution |
3 megapixel (Low-resolution camera) |
8 megapixel |
data |
Fast mobile data support (4G) |
Not much fast |
camera |
Rear Camera: 3 Megapixel Auto Focus Camera with LED Flash,Front Camera: 2 Megapixel Camera |
5 megapixel iSight camera,1080p video recording
Battery life |
Low compared with iPad 3 |
10 hour battery life, 9 hour battery on 4G |
Weight & thickness |
8.6 mm thick, weighs 1.25 lbs |
9.4mm thick, weighs 1.4lbs |
Android phone |
yes |
no |
