Difference between SD, SDHC, and SDXC
I’m always confused when buying SD Cards because of their types.
What is the difference between SD, SDHC, and SDXC?
You need not to be confused because SD stores upto 1-2GB of data and even 4GB, SDHC stores data from 4GB to 32GB whereas, SDXC stores greater than 32GB and upto 2TB.
Good day Roger,
What a good question you have there buddy,
SD, SDHC and SDXC are all non-volatile memory card used in different portable gadgets like cellphones, tablet computers, etc.
SD – stands for Secure Digital has three physical sizes available namely : Standard size, Mini size and Micro size
SDHC – stands for Secure Digital High Capacity, this type of memory can support up to 32GB.
SDXC – stands for Secure Digital Extended Capacity, this type of memory can support up to 2TB.
to sum it all up, MEMORY CAPACITY is the primary differences of all these three.
Hope I helped you,
Take care!
The “SD” initials in SD card stands for Secure Digital. It is a kind of non-volatile memory card that is designed to be used on portable devices like for example in GPS navigation gadgets, mobile handsets, digital cameras as well as tablet computers. This kind of memory card format or Secure Digital standard was initiated in 1999 as an evolutionary improvement over MMCs or MultiMediaCards.
This standard is maintained by the SDA or the SD Card Association. SD technologies have been employed to more than 400 brands over dozens of product types especially in more than 8,000 models.
The SD format is divided into 4 different types and they are SDSC or the Secure Digital Standard-Capacity, SDHC or the Secure Digital High-Capacity, SDXC or the Secure Digital eXtended-Capacity, and the SDIO or the Secure Digital Input/Output which merges the data storage with that of the input and output functions.
