Difference Between SSL VPN And Ipsec VPN
There are two type of Virtual Private Networks(VPN). I want to know which one is better? Which one to use when? What is the difference between SSL VPN and IPsec VPN?
There is a difference between SSL VPN and IPsec VPN. IPsec VPN stands for Internet Protocol Security Virtual Private Networks. SSL VPN stands for Secure Sockets Layer Virtual Private Networks. IPsec VPN works at the network layer while SSL VPN works at application layer. IPsec provides a permanent connection between locations. It also serves as a backup link in the event that connects the central office to the remote site. It supports remote access. There is no need of special software to be installed
Notifications
