I love taking screenshots on what I am doing for the day especially if I am editing pictures. I am running Mac OS and is using LittleSnapper to capture my screen and Sharpshooter to do some renaming on my screenshots. Can I download some other tools to do what I love to do better. I want to know more about littlesnapper vs sharpshooter as well.
Difference littlesnapper vs sharpshooter for my screenshots
Hi Linda,
You would be surprised that there are a lot of Screen Capture in the market, its your call if you want to download more screenshot apps, some may offer all in one feature.
If you want to know more about both softwares you are using I can list down their differences:
Little Snapper can make a screenshot of your whole screen not only the viewable part.
Sharpshooter helps you put labels on screens for more organized files.
Sharpshooter can modify multiple screens or individual screens.
Little Snapper has a browser so you don’t need to toggle between screens.
Hello Linda Nelson,
If you want to work with images or any other thing related to the graphics then you can use Photoshop that is a best software if you want to do your desired work. By using that software you can edit convert and also add other things to the images that you want to make. You can also work with your snapshot and also make then good use. I am giving you a link from there you can download that software.
https://adobe-photoshop-7-0-1-update.en.softonic.com/
