Hello!
I would like to know information about “ADS and ADS services” in Windows 2003. Also, can you cite the differences between the Active Directory of Windows 2003 and Windows 2000, as well as the difference between Group Policies of 2000 and 2003?
Thank you.
denmark
Differences in ADS and ADS Services
Greetings,
Hello Branden,
I have a suggestion and looking forward to give information and hope it will help you. Regarding your question in ADS services in Windows 2003 if this is ACTIVE DIRECTORY SERVICE in Windows 2003 you can check some guide on the link that I will give credit to http://www.computerperformance.co.uk/ it indicate information about active directory here's the link.
And if you are asking the difference between active directory of Windows 2003 and 2000 I will give some information and link that will credited this is the LINK . And about the group policies you can check some information and difference to this site and credited to tech-faq.com here's the link.
I hope it will help to answer the question.
