What distinct features and functionalities draw a line between dpp canon software for mac and windows platforms and what are the best ways to capitalize on these differences to obtain maximum utility for the application?
Differences between dpp canon software for Mac and Windows platforms
There is no difference between the dpp canon software for mac or a windows pc both have the same features and functionalities. Only difference you will notice will be a little change in the GUI (graphical user interface). Other then that both are the same in terms of functionality . I hope this helped.
Peter franklin
Hi Geraldine,
These days canon software is deployed as dual functionality which works equivalently on both Mac and Windows platform however depending upon the operating system difference you may find slight change in the upper interface i.e. View interface in both of them.
However if you are an artist or photographer professional you would prefer more Mac as its hardware are designed around graphic interface and also troubleshooting is more simpler.
Hope this helps.
Thanks
Baker
