Differences between the Windows NT Embedded vs. the Windows XP Embedded
Dear friend,
Windows XP has more improved features unlike Windows NT. Windows XP embedded has improved operating systems features, technological platform, and tools. Other areas of improvement include the booting time, memory management, and the device drives used.
The core operating system differences between the two windows are that the windows NT has device driver rollback, parallel processing of drivers, drivers signing, optimized disk defrag mentation, throttling, and simple booting time. While the windows XP embedded has the improved core OS like remote booting, windows pre – installation environment, and the system development image. In conclusion the embedded windows XP has more advanced and improved features of the core operating system.
Thanks!
Windows XP Embedded, often denoted by XPe, is a componentized version of the Professional edition of Windows XP. The user has the freedom to choose from 12,000 different components available based on your application needs. A basic XPe image can be as small as 8 MB in size with a bootable kernel and can expand to include many other features of the full version of Windows XP.
By using only the components you need you will be able to reduce development time, lower the hardware costs, and optimize your operating system size. This version of Windows XP is really intended to be used by developers. This is more reliable than Windows XP because of the operating system’s small size you will be reducing the attack area. There are a number of advantages on using XPe rather than the full Windows XP version like for example higher reliability, lower hardware cost, and rapid deployment. If you want to learn more about Windows XP Embedded or XPe, you may visit What Is Windows XP Embedded?
Windows NT Embedded is based on Windows NT 4.0 with Service Pack 5 and is the new version of Microsoft® Windows NT® 4.0 operating system. Windows NT Embedded has the following features:
For the full information about Windows NT Embedded, you may visit Windows NT Embedded.
