Guy J Lopez
Posted on - 11/15/2014
What are the distinct functions and features between CM Security Applock and Clean Master (Speed Booster)? Which of the two application software is highly recommendable to you for Android Smartphone users and why? What do these software applications also share in common with respect to technical functions and features? Lily is my name from Ethiopia.
Thank you.
Differences in functions and features of CM Security Applock and Clean Master
Both the CM Security Antivirus AppLock and Clean Master [Speed Booster] were developed by Cheetah Mobile and both were designed to run on Android Smartphones. The CM Security Antivirus AppLock is once more ranked number 1 by the AV-TEST. AV-TEST is a leading independent organization in Germany that performs regular evaluations on all antivirus products on the market and then gives awards for excellence.
The award they give is considered like an Oscar in the IT security and antivirus research field. They evaluate antivirus software according to how well or effective it can detect viruses and its user-friendliness. The latest version of CM Security Antivirus AppLock has a new sidebar that holds all your favorite features.
The photo missing bug of the vault that appears on some devices is now fixed. To download, visit CM Security Antivirus AppLock.
The Clean Master [Speed Booster] app, on the other hand, is focused on speeding up your handset while protecting it from viruses. It takes care of your phone’s junk files and analyzes which app is using too much CPU and stopping it to avoid overheating and wasting battery. If you don’t have this app yet, visit Clean Master [Speed Booster] to install.
