Different Adobe Illustrator Alternative Available
Hello everyone, my system for some reason is not allowing installing Illustrator on my system. Is there any Adobe illustrator alternative available? Kindly provide your suggestions
1. SVG Edit
SVG is scalable vector graphics and is mostly designing scales figured are done.
2. Inkscape
Also works in SVG format files. It has an intuitive and clear interface. It also has some advanced features like bitmap tracing, object cloning, etc.
3. Affinity Designer
A very excessive layer management and also supports multiple file format. It is a highly recommended illustrator and available for MAC user only. It costs $49.99, but you can use trial versions.
4. GIMP
GIMP is GNU Image Manipulation Program. It is entirely free and open source.
