Different kinds languages in programming
In the world of programming there’s a lot of language you can use, but what I want is the best language that can create a high technology gadget, what language it could be?
You can’t really compare the languages with each other all of them have their own pros and cons. For example Apple is using Objective-C (Mac OS X is also objective-C based) for development while Android application development is done in Java. For starting people usually use C and C++ that are very powerful and related to each other and transformation from C++ to Objective-C and Java is very easy. When you are designing a high end gadget it is more than probable that you use more than one language to implement different modules of it. For example when you are developing a Web based gadget you might use a combination of Html and C# (C-Sharp). So usually it’s down to what market you are hitting.
