Hello everyone, I want to switch my mobile to Lumia 1320. I am little confused that should I change or not. Kindly provide Microsoft Lumia 1320 review by comparing every possible different parameter. Thanks in advance for the help.
Different Microsoft Lumia 1320 Review On Unusual Parameters.
Microsoft Lumia best stands for its battery life. The capacity of its battery is 3400 mille ampere.
Talking about the camera is quite excellent than the other mobile of the same range. The rear camera is 5 megapixels, and the front camera is 0.3 megapixels. It comes with back flash.
The mobile is quite intense and bulky. Its weight is 220 grams.
It comes with single SIM quality and storage is 8GB, and RAM is 1GB.
Overall the review for this phone is although the mobile is heavy and bulky the battery capacity is excellent, camera quality is also good and reasonable good performance.
The Nokia Lumia 1320 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was unveiled on October 2013 and released on January 2014 measuring 164.2 x 85.9 x 9.8 millimeters and weighing 220 grams. It uses micro-SIM card and has IPS LCD capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution.
Nokia Lumia 1320
It supports multi-touch protected by Corning Gorilla Glass 3 featuring ClearBlack display. It runs on Microsoft Windows Phone 8 upgradeable to Microsoft Windows Phone 8.1 powered by Qualcomm MSM8230AB Snapdragon 400 chipset for the 3G model and MSM8930AB Snapdragon 400 chipset for the LTE model, 1.7 GHz Dual-Core Krait 300 processor, and Adreno 305 GPU. It supports microSD expandable up to 64 GB.
It runs on 1 GB RAM with 8 GB internal storage. The primary camera supports 5 megapixels with f/2.4, 28mm, LED flash, and autofocus featuring 1/4″ sensor size, touch focus, and geo-tagging. It supports 1080p video recording at 30 fps. It has a secondary VGA camera.
It has 3.5-millimeter jack featuring Dolby Headphone and Active noise cancellation with dedicated mic; Wi-Fi 802.11 b/g/n with hotspot support; Bluetooth 4.0 with A2DP, EDR, and LE/aptX support after WP8 Denim update; GPS with A-GPS and GLONASS support; FM radio; and microUSB 2.0. It has built-in accelerometer, proximity, and compass sensors. The pre-installed web browser supports HTML5. Java is not supported.
It runs on non-removable BV-4BW Li-Ion 3400 mAh battery with standby time up to 672 hours both on 2G and 3G. Talk time is up to 25 hours on 2G and 21 hours on 3G. It is available in yellow, black, white, and red colors.
1....
