Different Microsoft Lumia Phone Range In India.
Hello everyone, I am currently using iPhone, but I want to try for Microsoft. I live in India, so I was curious to know what the different Microsoft Lumia Phone Range in India are.
There is a big range of mobile phone with various features and of different range.
Few phones are listed below:
i. Lumia 430 DS.
This phone is dual SIM and has the screen of 4.0 inches. The camera is 2 megapixels, and resolution is 480 * 800. RAM is 1 GB. Internal storage is 8 GB.
ii. Lumia 435 DS.
This phone is also dual SIM and has the screen of 4.0 inches. The camera is 2 megapixels, and resolution is 480X800. RAM is of 1 GB. Internal storage is 8 GB. The battery capacity is 1560 mAh.
iii. Lumia 532.
This phone is single SIM and has the screen of 4.0 inches. The rear camera is 5 megapixels, and the front camera is 0.3 megapixels resolution is 480×800. RAM is 1 GB, and internal storage is 8 GB. The battery capacity is 1560 mAh. It runs on Windows 8.1 operating system.
iv. Lumia 540 DS.
This phone is also dual SIM and has the screen of 5.0 inches. The camera is 8 megapixels, and resolution is 720×1280. RAM is 1 GB, and internal storage is 8 GB. The battery capacity is 2200 mAh. The phone comes with a flash also.
v. Lumia 550.
This phone is single SIM and has the screen of 4.70 inches. The rear camera is 5 megapixels, and the front camera is 2 megapixels, and resolution is 480X800. RAM is 1 GB. Internal storage is 8 GB. The battery capacity is 2100 mAh.
vi. Lumia 950.
This phone is also dual SIM and has the screen of 5.20 inch. The rear camera is 20 megapixels, and the front camera is 5 megapixels, and resolution is 1440×2560 pixels. RAM is 3 GB, and internal storage is 32 GB. The battery capacity is 3000 mAh.
vii. Lumia 950 XL.
All the features are as same as Lumia 950 except that the display screen is of 5.70 inches and has octa processor.
Among the devices in the Microsoft Lumia series is the Nokia Lumia 630 or Microsoft Lumia 630. The Microsoft Lumia 630 is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled on April 2014 and released on May 2014 measuring 129.5 x 66.7 x 9.2 millimeters and weighing 134 grams.
It uses micro-SIM card and has IPS LCD capacitive touchscreen display with 16M colors at 480 x 854 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass 3 featuring ClearBlack display. It runs on Microsoft Windows Phone 8.1 powered by Qualcomm Snapdragon 400 chipset, 1.2 GHz Quad-Core Cortex-A7 processor, and Adreno 305 GPU. It supports microSD expandable up to 256 GB.
It runs on 512 MB RAM with 8 GB internal storage. The primary camera supports 5 megapixels with autofocus featuring geo-tagging, panorama, and 1/4″ sensor size. It supports 720p video recording at 30 fps. It doesn’t have secondary camera.
It has 3.5-millimeter jack featuring Active noise cancellation with dedicated mic, Wi-Fi 802.11 b/g/n with DLNA and hotspot support, Bluetooth 4.0 with A2DP and LE/aptX support after WP8 Denim update, GPS with A-GPS and GLONASS support, FM radio, and microUSB 2.0. It has built-in accelerometer and sensor core sensors. The pre-installed web browser supports HTML5. Java is not supported.
It runs on removable BL-5H Li-Ion 1830 mAh battery with standby time up to 600 hours and talk time up to 16 hours 20 minutes on 2G and 13 hours 10 minutes on 3G. It is available in bright yellow, white, black, bright orange, and bright green colors.
