Different Microsoft Wired Desktop 600 Specifications
Hello, experts, I want to purchase Microsoft wired desktop 600. Kindly provide me the specifications of the product.
1. Control through play/pause, volume up, volume down, and mute buttons are present in the center of the keyboard.
2. The keys are light and thin.
3. Access to the calculator is much easy with keys.
4. It can easily withstand with any accidental spill.
5. To view the start menu just press the window key present on the keyboard.
6. No external software required just plug-in and easily you can use it.
7. The DPI is 800-dots-per-inch and delivers a great accuracy and control.
The dimension of Keyboard:
Length is 17.9” and width is 6.28”.
The dimension of Mouse:
Length is 4.47” and width is 2.28”.
