Different sizes of items in the menu using TMPGEnc DVD author
Hi guys,
I am using TMPGEnc DVD author 3 for a week now, but I am experiencing some problems. My first problem is that the size of all the items in the menu is not the same. One item appears to be bigger than the other, although all the images are from a single video file.
I cannot change the size of the source. I have tried a lot of solutions, but none of them worked. I tried applying a new template and then also recreated the files in a different location, but still, the sizes of all the images do not match. You can all see it in the screenshot I have attached below:
When I try to burn a DVD for the above items, I get to see the following screen:
TMPGEnc DVD Author 3
No stream available. (error code 0x80048001)
             OK
I have successfully been using this software to build up DVDs before and never faced any trouble. I don’t know what went wrong this time. Can anyone help me out please?
I'm really worried what to do, as I have not found a solution yet.
Waiting for your feedback.
Regards.
