Difficult uninstallation of Nero Burning ROM Software
This is common, many programs get corrupted (Uninstaller). There are 1000's of uninstalling software available in the internet.
Try this first :-
Ways to uninstall Nero 11 from your PC:
For Windows USERS:
1. Click on Start menu.
2. Click on “Setting” and then click Control Panel.
3. Double click to open Add/Remove Programs.
4. Scroll down for the program list and right click the Nero 11 program.
5. Click a “Change/Remove” button.
6. Click on “Uninstall” when the windows come up.
7. Follow the on cover steps to finish the uninstallation of Nero one by one.
IF THAT'S NOT WORKING ONLY TRY THE BELOW INSTRUCTIONS :-
To get rid of NERO from your computer, then you can use a third party software.
Nowadays Perfect Uninstaller is the most used remover software to either uninstall or forcibly uninstall unwanted or corrupted program like any Nero 10 from hard disks and registry with 100% efficiency.
You can download perfect Uninstaller from the below URL site:
If you tried uninstalling Nero using the built-in uninstaller but it always fails, try uninstalling it with third-party software like Revo. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select Nero among the applications and click “Uninstall”. Follow the normal uninstall process. When you are prompted to restart the computer, click to restart later.
When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo then restart the computer. If the problem continues, try to force uninstall it. In Revo Uninstaller, click “Forced Uninstall”. In the “Forced Uninstall” dialog, click “Browse for” then select “Folder”.
In the “Browse for Folder” dialog, navigate to the location of the program or the installation folder of Nero, select it then click “OK”. Click “Next” then follow the instructions.
1....
