bryan dowdy
40 points
Posted on - 07/27/2012
Hi all,
I'm using xcode 4.4 and having difficulty in installing the command line tools.
I need a mac developer for advice! I'm using DP3 and I'm having to hit the checksum error constantly.
Downloads
Failed to mount file://localhost/Users/
taylor/Library/Caches/
com.apple.dt.Xcode/Downloads/
Xcode.CLTools.10.8-1.2.dmg at file://
localhost/var/folders/
x9/8nmpgy7x38775fznw4z64zqm0000gn
/T/attached-
image-4deada352a9421b174941c6fc10b
90fd562ebf2e/: invalid checksum
OK
I re-downloaded the program, but alas, that has made no difference. I really need all of this.
Can you offer me any advice?
Difficulty in installing the command line tools
Well, here is your respective person whom you are looking for, Just follow my instruction and your problem will be solved. Now watch it carefuly,
1. There are some Difficulty to install automatically, Xcode < 4.3 downloads from the Mac App Store are not installed automatically. You need to manually run the application “Install Xcode ” from your Applications folder.
2. After installing Xcode 4.3, the Command Line Tools must be installed. This is done from the Downloads section of Xcode's preferences.
3. If you wish to create Installer packages with port pkg, you will also need to install PackageMaker, which is in the "Auxiliary Tools for Xcode" package as of Xcode 4.3. The download page for this package can be opened via the Xcode -> Open Developer Tool -> More Developer Tools… menu item. After downloading and mounting the disk image, drag the PackageMaker application to your /Applications directory.
Thanks again,
Bett Salvandor.
