Difficulty in Managing Folders in Windows Vista
At my workplace we have three computers; one of them is a Toshiba and the other two are Dell and Sony respectively. Both the Sony and Dell computers are running on Windows 7 while the Toshiba runs on Windows Vista. Each computer has a document file located in the library and all the files have green folders. There is a Manila folder that is named Documents which also has a green folder that is saved as documents. The Manila folder is found under documents. The Toshiba, on Vista OS, is giving me a rough time with these folders. When I delete the extra folders all the other folders are deleted. Another problem is that I end up having three folders with similar content when I save a downloaded file in the manila folder named documents, then transfer it to the root folder. The Dell and Sony computers on Windows 7 on the other hand don’t have this error. I have been unable to figure out this problem and so I am seeking for your help on this matter. Any idea that will solve this problem is welcome.
