Digital Blue QX7 Microscope connection error
Does the QX7 Microscope require a driver to be installed for Windows operating systems?When I tried to launch the QX7 Microscope Special Effects Software the following error 102 message appeared. Suggest me the proper solution to resolve the error message. I would be grateful to you.
Thanks in advance.
Error: Your Micrscope is not plugged in. Please connect your microscope. (102).
