Digital camera photographs displaying within the camera but not throughout laptop/computer
I got your problem. Normally digital cameras make use large sized high resolution images, which are highly volatile .Instead of using the camera software to recover pictures from digital camera u have to use a recovery tool that recovers your missing images but be sure that you have not used the card further for storage purpose. To recover pictures from digital camera i recommend this tool as it gave me a good result on the same problem in canon power shot SD880. Or you can put your sd card in the camera and connect the camera to the PC. If you are still having problem then reinstall the drive after uninstalling it in device drivers.
