I need to retrieve digital media from my storage device and computer on a specific network.
I also need to display them on my home theater system or television.
What specialized entertainment device do I need?
I would be glad for the answer to this.
Thanks a lot.Â
Digital media from my storage device
You can do this easily by selecting the Automatically allow devices to play my media option from stream menu in your windows media player.
Of course there are some requirements like being connected to a network and organizing your media with Manage library option.
You can also allow internet access to share your media across the web not only with another device.
Regarding connecting your PC to a television or a home theater system you can use a cable to connect between them.
For more information and detailed steps you can check here
