Digital Storms unveils its new Marauder Series PC System for gamers and have been built using Corsair's Vengeance C70 chassis. How many slots of hard drives can Vengeance C70 chassis supports?
Digital Storms Unveils Marauder Series PC System for Gamers
Hi there Mikey,
The corsair Vengeance C70 is one fine looking case, from the design one would say that the design is military inspired, it doesn’t looks that look tough, the case is rigid enough to handle eight PCI-E slots, Six slots for SSD ready HDD bays with two removable drive cages, 10 fan mounts and dual USB 3.0 Ports. The colors available for the Corsair Vengeance C70 are Artic White, Gunmetal Black and Military Green. The C70 case also has a bottom mounted HDD cage and enough room for water cooling solution like Corsair’s own Hydro series or any other water cooling solutions with 240mm top mounted radiators, the bottom mounted HDD cages can be removed to install another 240mm bottom mounted radiator. Â
