Is it possible to digitize physical media like records and tapes. If you have data on tapes how can you get that data to a computer or digital device? If there are programs involved please list them as well as the method to get this done.
Digitizing physical media like records and tapes
Yes you can copy all recordings and songs from your tape recorder to your PC. But you need a digital USB cassette deck for that. Manufacturers have made this USB deck to easily digitalize tape recordings. These deck feature a USB port to connect to a computer and record the files with any audio recording software. You can play the cassette and it will be recorded in your PC. So you should first one of these USB cassette deck. The best and reasonable option would be to purchase Bravolink USB cassette deck for only 17$.
Hope it helps!
Wagner Desantiago
