Randy Baier
30 points
Posted on - 03/24/2013
Hi, I have a pile of old documents that need to be converted to readable PDF. I need a direct converter of files on word 97 to pdf freeware. It seems that on some software I have to convert word 97 to word 10 first before I export to PDF. Is there an easy way?
Direct converter of word 97 to PDF freeware
Hi Randy Baier,
Converting docs to PDF is easy if you have a PDF converter such as Adobe Acrobat X or Adobe Acrobat XI and other PDF converters downloadable on the internet today. Adobe Acrobat converts MS Office documents whether it is 97 – 2013. But unfortunately Adobe Acrobat is not free of charge, you can download trial for free but it has limited features. I will give you a link to a free PDF converter. It is call doPDF converter. It is free for both personal and commercial use.
You can create PDF by selecting the "Print" command of virtually any application.
