Direct x for fifa 09
Dear Emonalam,
It is really very common problem and gamers usually face this problem. Most of the games need the updated DirectX. As you are using Microsoft XP so you need to upgrade your DirectX Microsoft’s webpage. After upgrading it your problem would be resolved.Â
Get your updated version from here…
Best wishes-Â
Devid James
If you installed FIFA 09 and you keep getting an error related to Microsoft DirectX every time you want to play it, you need to check the game’s system requirements again. Check that your computer meets those requirements. FIFA 09 supports Windows XP Service Pack 2, Window Vista, and Windows 7.
It requires 2.6 GHz Intel Pentium 3 or faster processor, 512 MB RAM, Microsoft DirectX 9.0c-compatible video card with 128 MB video RAM and with Pixel Shader 2.0 and Vertex Shader 2.0 support (NVIDIA GeForce 6600, ATI Radeon 9800 Pro, or better), 4.26 GB free space, and sound card. If you have Windows XP, update your operating system to Service Pack 3.
Download Windows XP Service Pack 3 on FileHippo. This is the latest and last Service Pack update for Microsoft Windows XP. If the problem with Microsoft DirectX continues, upgrade your video card.
