Francis Pan
10 points
Posted on - 10/21/2011
Director Player is continuously beeping the following message and asking for Xtra (text).
I don't know what is this and how can it obtain.
I am new in PC uses, so if you have experience on it, please share your idea.
Director Player Error
This application requires an Xtra (Text) that either does not exist or failed to initialize properly.
Please make sure the appropriate Xtras are in the Xtras folder(s).
Francis
Director Player Error – This application requires an Xtra (Text) …
There are also some instances where this error appears while you are playing a game on your computer or maybe playing a video. Depending on what application you are using when the error appeared, make sure that it is installed properly. An incomplete installation of an application may also cause this error.
Check your video card’s driver if it is working properly by accessing the Device Manager in My Computer. If the device is working properly, try upgrading it if it’s possible.
Run a disk check on your computer. An error in the hard drive’s file structures might cause this problem. If you have your own disk utility application installed on your computer, run it to check your disk. Or else, use Windows disk check.
Right click on drive C and then select Properties.
Click Tools tab.
Click Check Now.
Check Automatically fix file system errors and then hit Start.
Run the application again after the disk check. If the error still keeps on appearing, read the application’s documentation or its readme file. Maybe there is a support application that you missed to install together with the application.
