I have a small problem on my laptop.
When I want to play a sound file, the following message: DirectSound Driver incorrect.
Please install proper drivers or select another device. Error code 88780078.
I tried all means, but to no avail.
I just ask for your help:)
Thank you in advance!
CandyJ
Error code 88780078: DirectSound Driver Incorrect
The features of your Sound Card is off. You must activate the features to use your Sound Card properly:
click start
open your Control Panel
open Sounds and Audio Devices
open the Hardware tab
your Sound Card should be in the list if your Sound Card is properly installed.
select it and click Properties
select "Use this device (enable)"
click OK
restart computer
If your Sound Card is not in the list I mentioned earlier you have to:
uninstall your previous installation of your Sound Card
restart your computer
if you have the CD of your Sound Card Driver install it(the right installer not the wrong one) if not download your Sound Card Driver
install your Sound Card Driver
repeat the first the steps i mentioned above just to make sure your Sound Card is enabled.
I have read your problem.
The solution is here.
1. Go to My Computer/Manage/Device Manager . Now you will see the list of all your devices. Now select Winamp preferences (Ctrl+P) then click on output .
There is an option to select Direct sound output. Now select Dll(Out_ds.dll).YOU will see the changes. If there is any changes reset it to my soundcard.
I am sure this will help you.
That error means there is a problem with your sound card or its driver. To fix the problem, check if the driver is already installed. If the driver is already installed, try to uninstall and reinstall the sound card driver. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select your sound card software among the applications and click “Uninstall”.
Follow the normal uninstall process. When you are prompted to restart the computer, click to restart later. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo then restart the computer. After booting, install the sound card driver back.
On the other hand, if you haven’t installed the driver yet, you need to install it first to be able to play music on your computer. Download the latest sound card driver from the following if your machine is from these manufacturers:
If the problem continues, try updating DirectX. Try installing the latest Microsoft DirectX runtime for your operating system. See the following list for a possible download:
- Microsoft DirectX 9.0c End-User Runtime – this Microsoft DirectX update is intended for Microsoft Windows XP and Microsoft Windows Server 2003. This downloads the web installer. If you want the offline installer, download this Microsoft DirectX 9.0c (June 10) on FileHippo.
- Microsoft DirectX 10 – this version is included in Windows Vista and there is no offline update package for this version. To update, install the latest Service Pack for Windows Vista.
- Microsoft DirectX 10.1 – this version is included in Windows Vista Service Pack 1 and Windows Server 2008 Service Pack 1.
- Microsoft DirectX 11 – this update is available for Windows Vista and Windows Server 2008 Service Pack 2 with KB971512 installed. This version is included in Windows 7 and Windows Server 2008 R2.
- Microsoft DirectX 11.1 – this update is available for Windows 7 and Windows Server 2008 R2 Service Pack 1 with Platform Update for Windows 7 and Windows Server 2008 (KB2670838). This version is included in Windows 8, Windows RT, and Windows Server 2012.
- Microsoft DirectX 11.2 – this version is included in Windows 8.1, Windows RT 8.1, and Windows Server 2012 R2.
- Microsoft DirectX 11.3 and Microsoft DirectX 12 – these versions are included in Windows 10 and Windows Server 2016 Technical Preview.
