DirectX(R) encountered an unrecoverable error
Hi Experts,
My Xfire ingame option has encountered a problem. It has thrown an error message regarding DirectX error.
Have you any idea for this type of error?
Have a look at the error message below.
Please help me to solve it.
Thanks in advance.
DirectX Error
DirectX(R) encountered an unrecoverable error.
Check the DirectX(R) FAQ for possible solutions.
Answered By 0 points N/A #154442
Direct X is a program or application that uses to communicate between your system and your video card adaptor. It is one of the important components of your system, without this the quality of display you have is poor and it cannot support games or application that requires a high graphic definition. There is a problem between your program and the DirectX application. One cause also is that, the application required a higher version or higher video card capacity.  Check the system requirements of your application or reinstall the DirectX application.
Regards!
