Disable any items on start-up pops up
I have a problem that whenever I disable any program using ‘msconfig.msc’ and restart my PC then it displays a pop up that you have blocked ‘XYZ’ program. Can anyone tell me how to disable this?
There are few possible things that you can do:
1. Go to start and click on Run.
2. When the message box appears there is a checkbox saying "Don't show me this message again". Check it and it won't happen again
3. Sometimes it keeps on coming again and again. For this try to go to msconfig again.
Hello Dear,
Thanks for sharing your problem with us.
Dear you do not have need to type .msc with msconfig.
Just type msconfig in run menu and press enter.
It will open a program. Click on startup and remove ticks from unwanted software. Or that software that you do not want to run can be disable.
Then press Ok button.
It will ask you if you want to restart your computer. Just click on restart now. It will restart your computer. When your computer will be restarted. You will see a new message related to your current action.
Just click in the check box and press OK.
It will absolutely fix your problem.
ThanksÂ
