Disable caps lock remotely Mac
Hello,Â
I want to disable caps lock remotely mac. I am using Mac system. Please send me the complete solution for disable caps lock remotely mac. Thanks in advance!Â
Regards
Hello,Â
Regards
1. IN System Preferences menu by going to the Apple icon and clicking on it.
2. In the System Preferences menu click on Keyboard, it is under the Hardware section.
3. Under the Keyboard menu go to Modifier Keys, which is at the bottom right of the screen, and click on it.
4. You will get a prompt from the Modifier Keys menu. Locate Caps Lock at the top and click the drop down menu to the right and select No Action.
Click Ok when you are finished.
