Disable Easy Homepage Creator when starting up Windows 7
I recently installed Easy Homepage Creator. It runs whenever Windows 7 starts and it seems its making my computer quite slow. I need to know how to disable Easy Homepage temporarily and then enable once I need it.
Thanks in advance!
Answered By 10 points N/A #191857
If you want to remove a program temporarily, use the custom uninstall option. Follow the steps below:
1. Go to Control Panel on your computer and scroll down to the Easy homepage creator.
2. Right click and click on uninstall. In the new window, select custom uninstall option and click ok. The custom uninstall removes only the main system files but not the saved files and registry settings. So when you want to use it again the installation process will be very quick and your system will not slow down.
3. Remember to save the setup file in a place easily accessible to you so that whenever you need to access it you can install it immediately.
Hope this information helps you.
