Hello friends,
A problem about funny texts featuring computers. From the time I open my laptop with windows 7 starter operating system an icon will pop up form my system tray about funny texts featuring computers, such as computer backgrounds, hardware in a random way. I would like to get rid of those things. I hope you can help me.
Thanks and Regards,
Chloe Chylly
Disable Funny Texts Pop-up Icon in Windows 7
Hi Chloe!
It's easy to get rid of those things.
Just follow these simple steps:
1) Click the arrow on the right side of the taskbar that is facing upwards.
2) Click on Customize.
3) A window will open and there you will see all the list of icons and notifications.
4) Choose a behavior for the icon you want to change. (If you want to completely disable notifications, then choose Hide icons and notifications)
5) Done.
I hope it helps!
