Disabling all links on clicking one link
Good day and I need the code for disabling all other links when clicking on a link ( eg..20 links r 10 links are there if we click on one link then all should go to disable mode) and it should be written on " masterpage.master.cs " file so kindly help me out with the code asap.
Thanks Kaushik
Best Answer by Ronald B Cline
Answered By 45 points N/A #125990
Hello there Kaushik,
All you need to do to disable your link is to configure or to make some codes in your HTML using JavaScript or CSS.
There are a lot of tutorials out there to help you achieve what you want. You can Visit for some tutorials and view some discussion about disabling a link.
Hope this helps you.
Regards, Roland.
Answered By 10 points N/A #125991
Hi Kaushikthallam,
Want to protect your source code? Using this code will prevent the vast majority of users from right-clicking over a page and choosing "View source", or right-clicking over an image and saving it.
All source code are in attached file.
Thanks for asking.
