Disabling auto updating of WMC
How do I disable WMC auto update? My computer automatically wakes up at night and tries to update my WMC. However, I checked my WMC and no auto updates were enabled. Can anybody help me turn the auto update off?
Hello there!
You probably have WMC updates disabled using this procedure: Tasks > Settings > General > Automatic download options > Uncheck 'automatically download Windows Media Center data: > Save. But then your problem persists. It is because that option does not always work on many computers. You are not the only one experiencing that problem. You want to stop updating WMC because maybe you do not like WMC and think that it's a worthless piece of nonsense. You and I have something in common.
Well, here is one solution that I, and many other people have found effective in disabling automatic updates for WMC:
1. Open Task Scheduler (run > type in "taskschd.msc /s" and click OK)
2. On the left hand side of the Take Scheduler window, double click on "Task Scheduler Library." Then double click as follows: "Microsoft," "Windows," and "Media Center."
3. Look for "mcupdate" in the middle panel. Right click on it and select "Disable." (some can find two entries of that same name, disable both of them)
I hope this helps! Good luck!
Hello Astene,
The steps to disable Windows Media Center auto update are as follows:
Hope this helps.
Carl
