Chase Evans 210 points N/APosted on - 06/14/2011
Hi all,
My manager recently purchased a Compaq Presario CQ60 for me. This laptop has Windows Vista Ultimate installed on it.
I placed it on our domain at work; however, each time i want to make a change on my laptop ,i get an error message saying the User Account Control stops unauthorized changes to your computer. I get the option to click on Continue or Change.
If i choose Continue, I need to fill in a user name and password.
I would like to know ,if it is possible to disable User Account Control and how that is done?
If this is not possible, is there a way to prevent it from asking for a user name and password? Can't I save that information so it would remember it?
Please see an example of error message below.
A program needs your permission to continue
I will help you disable User Access Control from your Windows Vista Ultimate running computer. It is very annoying but it a security feature in Windows Vista. To disable UAC, go to Control Panel and click on Users and Accounts. Then go to your user account. Then you see a line Disable User Access Control.
Like you, I also get annoyed with UAC or User Account Control always appearing every time you do something on your computer like installing a driver or applications. The good news is it can be disabled for a peace of mind. To disable User Account Control, click “Start” then “Control Panel”. Set the view to “Small icons” then click “User Accounts”.
On the next screen, under “Make changes to your user account”, click “Change User Account Control settings” at the bottom.
Click Change User Account Control settings
In “User Account Control Settings” window, move the slider all the way down to “Never notify”.
Set to Never notify
When you are done, click “OK” and that’s it. UAC is now turned off.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
