This disc is not formatted to play in this region
Media center is returned to a following error when I'm going to try to play the following titles requiem and Armageddon etc. 20th can fox background.. This disk is not formatted to play this, current system, custom, build media player,.. Asus at3n74 GPU, motherboard mini it pioneer bud 205 blue ray updated any DVD, HD 6.7..1.0..This is discrete problem or a codex? Or something else?
Answered By 0 points N/A #186950
To play DVD you must have a DVD ROM drive or a software plus hardware DVD decoder already installed din PC if you haven't compatible dvd related all commands you need options ND controls will not appear the player and you can’t play dvd as you are getting an option to reset or update the firmware you need to contact to the manufacture of the PC of the DVD driver for the same problem.
You may have to again install all their CD or driver
1) Tick starts typing DEVMGMT.MSC $PRESS enters
2) Tick DVD /CD driver and right tick and uninstall
3) Restart PC
4) Visit manufacturer web and download latest driver
5) Install driver or restart PC for the change to take effect.
