Disconnect USB in the wrong way and now pen drive is spoilt
Hello there,
I disconnect my USB in the wrong way and now my pen drive is spoilt. I would like to know how can i return things to normal once more. The windows I use do not recognize my damaged pen drive.
The pen drive has two USB slots. Thanks for your answer.
Answered By 10 points N/A #93676
 Though windows tell it is not mandatory to remove USB pen drive with “Safe remove” icon but it is not always good. Sometimes USB devices are not recognized because those become malfunctioned. Have you tried other ports too? If there is a physical damage, broken memory chips, damage on controller it cannot be repaired. If think your USB device is ok then tries a USB repair tool. I think there is a problem with your firmware. Mainly it happens after system updates. Depending on your problem solution is large. So I think if you visit https://www.cnet.com/news/tutorial-common-fixes-for-usb-device-issues-unrecognized-etc/ for your issue, it will help you must. Hope a good luck.
