Disconnected the session because of an error in the licensing protocol.
Windows 7 system get this error
Remote Desktop Connection
To fix this problem, you will need to reboot your computer and then try connecting to the remote computer again.
In the event that you continue to receiving this error message, you will need to contact the server administrator.
This problem might also be as a result of corrupt registry entries. If that is the case the following steps should help you fix it:
Carl
A lot of users have also experienced this problem when connecting to a remote computer. According to Microsoft, the cause of the problem is that “the licensing protocol handles the communication of licensing information between your computer and the remote computer. If there is an error in the licensing protocol, your computer cannot be connected to the remote computer.” They suggest to try connecting to the remote computer again.
Here’s a workaround that seems to work with most users by removing a key in the Windows registry. Click “Start,” “All Programs,” “Accessories” then right-click “Command Prompt” and select “Run as administrator.” In the command prompt window, type without quotes “regedit” then hit Enter. In the Registry Editor window, go to this location: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSLicensing]. Delete the “MSLicensing” key. Close the Registry Editor window and restart your computer.
Next, click “Start,” “All Programs,” “Accessories” then right-click “Remote Desktop Connection” and select “Run as administrator.” For users with Windows Vista and Windows 7, you need to run the “Remote Desktop Connection” shortcut using the “Run as administrator” option. For Windows XP, just run the shortcut. See if this works.
